1999 2500 V-10
Old Jul 29, 2007 | 09:30 PM
CaseInternational's Avatar
CaseInternational
Default 1999 2500 V-10
Hello Everyone!
I am going to try to go to the stealership tomorrow and look at a 1999 2500 4x4 with the V-10 and 4-speed auto transmission. It has 100,000 miles and some change, and from what I can tell by looking at the outside and the inside of the cab, it was pretty well taken care of. The paint is not to scratched up and it has all the hook-ups in the bed for a camper so I would think it is safe to say a lot of the miles were all highway. It has brand new B/F Mud Terrain tires and a new spray in bed liner.
1. Besides the death wobble what else should I look for while driving the pickup?
2. With 100,000 miles on this, how much more life should I expect out of the engine?
3. Same question as above but how much should I expect on the transmission?
Any other info you on these would be appreciated. Thanks, Jeff
Old Jul 29, 2007 | 09:40 PM
rhaines00ram's Avatar
rhaines00ram
Default RE: 1999 2500 V-10
Id look at the trans fluid make sure its not brown or dose'nt smell burnt . Id try out the 4wd too mine had bad ujoints in the front end I made them fix before i got mine
Old Jul 29, 2007 | 10:18 PM
spaz_22's Avatar
spaz_22
mostly the usual stuff. Steering play, driving straight. braking performance without any brake pulsation or grinding noises, ect. make sure all your accesories work, like headlights, foglights, windows, ect. If you going to pay for the stuff, you should make sure it works right?
Old Jul 30, 2007 | 10:04 PM
ramron's Avatar
ramron
I work at jeep in toledo .I also own a V10 so do some of my freinds. best damn engine to own lots of power and torque. some have 200;000 miles with no engine problems at all...good luck
