Roller Rocker questions..
Old Jul 30, 2007 | 01:28 AM
mikerados21's Avatar
mikerados21
Default Roller Rocker questions..
#1. What all do you have to take off your engine in order to replace your roller rockers for 1.7 Harland Sharps?
#2. Do you have to get different valve covers?
#3. Is this all i need to buy to install roller rockers....
http://store.summitracing.com/partde...p;autoview=sku
Thnx Guys!!!
Old Jul 30, 2007 | 11:09 AM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: Roller Rocker questions..
-All you need to remove is the valve covers, and disconnect the plug wires (so they can be moved out of the way). You will need to disconnect the items that connect to the valve covers too (PCV, air cleaner vent tube, and the various wire harnesses that use the valve cover bolts to hold them down).
-No, you do not need new valve covers with HS rockers.
-Thats about all you will need. I would also get a bottle of engine assembly lube, and some new valve cover gaskets. Also change your oil after you do the install.
Here is a good write-up on the rocker install.
http://www.pavementsucks.com/tech/rollerrocker.php
Old Jul 30, 2007 | 11:43 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: Silver_Dodge
Why new valve cover gaskets? The Magnum valve cover gasket is reinforced rubber, meant to be reused.
Old Jul 30, 2007 | 12:29 PM
Silver_Dodge
I just always like to do new gaskets whenever I remove something. Personal preference I guess.
Old Jul 30, 2007 | 01:40 PM
Fox Fader's Avatar
Fox Fader
How much power over stock will these produce on the Magnum?
And how much are they?
Old Jul 30, 2007 | 02:32 PM
aim4squirrels's Avatar
aim4squirrels
Will rr's make that big of a difference on the 5.2L? There was an article going around a little while ago with guys pulling ~405hp from a 318 and they left the stock rockers in sighting the engine was better designed for short stroke, fast rpm, but I guess that could have been for a different application.
Old Jul 30, 2007 | 11:55 PM
Silver_Dodge
I thought they made a very nice difference on my 5.2. Do a search on my name, you can find the thread I talked more about them.
Old Jul 31, 2007 | 05:35 PM
mopowar's Avatar
mopowar
ORIGINAL: aim4squirrels
A cam will do wonders compared to 1.7 rr's ( cam had to play a large role in pulling 405hp ), but if you are running the stock cam 1.7's would be an improvement.
Old Jul 31, 2007 | 06:49 PM
aim4squirrels
Oh, got ya!
Old Aug 1, 2007 | 09:06 AM
turkeyhunter1962's Avatar
turkeyhunter1962
The 1.7 rr's are what's called the 'poor mans cam upgrade'. It will improve your performance but I am uncertain how much. While you are in the engine replacing the roller rockers, pull your push rods one at a time and check them for bends. I do this by rolling them on a piece of glass. If you see a bend, replace it. If you are re-using the push rods after checking it make sure you insert it back into the same lifter you pulled it from with the lifter end of the push rod back in the lifter and not turned upside down.
It's just a good time to check these and replace them if necessary. I found the NAPA was able to obtain replacements, but I didn't need them.
