truck stalled and now wont start
We have a 2001 Dodge Ram Dually 3500 5.9L Diesel. This past weekend we went away for vacation. We parked the truck and then about 10 minutes later we were asked to move it. We started it up and went to move, it puked a little and just stalled out. It took a few tries, but it did re-start. Then it did the same thing the next day. We replaced the filter, primed it, new 0-ring...blah blah blah. Truck sat overnight and in the morning we were preparing to leave and it died on us again before we could get moving. It did this 6 or 7 times, it finally started and blew a ton of white and blue smoke!! A friend of ours kept bleeding the air out of it. He said it is sucking air somewhere. Finally got it started and got it home, but then it died completely as we were taking a golf cart back. We had to be towed home. It will not re-start this time. Not even sure where to start with it. Some people are telling us it is the injectors, a crack or a bad fitting in the fuel lines, a lift pump, an injector pump, or just bad fuel. If anyone can give me some guidance, that would be great. Just want to know where to start
You may want to post your problem in the cummins desiel thread, you'd get a quicker reply there then here because it seems most guys here own the gasoline trucks.
