Any tips or tricks?
Old Aug 4, 2007 | 07:37 AM
HankL's Avatar
HankL
Default RE: Any tips or tricks?
Mopar Rust Penetrant
MS-3613
Part Number 04318039AB
is also very good for getting bolts loose.
This official spray can from Chrysler seems to have little
particles of graphite along with the penetrating fluid.
Old Aug 4, 2007 | 08:05 AM
Muncie4sp's Avatar
Muncie4sp
Air Tools and yeah... PB blaster
Old Aug 4, 2007 | 01:03 PM
RamManRiley's Avatar
RamManRiley
ORIGINAL: HankL
MS-3613
Right there thats what we use at my shop, best stuff on the market.
Old Aug 4, 2007 | 01:14 PM
Fox Fader's Avatar
Fox Fader
I'm not exactly sure what you are doing, are you putting
headers on or oe mani's?
As far as PB, I'm hip, start yesterday. My exhaust will be here Wednesday and I started soaking yesterday.
Old Aug 6, 2007 | 06:35 PM
Moparkid032's Avatar
Moparkid032
well they are all on...it pops a little asa you rev it up...hopefuly a small exhaust leak...but besides that it sounds pretty descent..now if i onl didnt blow my brake line than i could finaly drive her again
Old Aug 6, 2007 | 07:16 PM
shott8283's Avatar
shott8283
along with the PB blaster.. the next upmost important item.. saftey friggen goggles.. cant tell you how many times i was under my truck monkying with them garbage eddie headers (replacing the donuts everymonth) and my arm bushes against 1 of the 1000000 things under there and a good 1lb of rust flakes, mud, stones and who knows what else drops directly into my friggen eyeball..
Old Aug 7, 2007 | 07:55 AM
HankL's Avatar
HankL
I sure agree with shott8283 on the eye protection,
especially if it is comfortable
so that you tend to wear it.
The Sears Tools section has some safety glasses
with small LED lights built in that can be handy
underneath a vehicle
http://tinyurl.com/2355l2
Clear Gargoyles along with a Petz LED headlamp are also good.
Old Aug 7, 2007 | 09:53 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
I usually apply PBlaster and wait a while before hitting the affected part with some heat. After a few moments of that, I spray it again with PBlaster. The oil from the PBlaster will cool it and even penetrate a bit better. Heat it again, and then try to remove the affected bolt.
Before reassembly, I coat the threads with anti-sieze.
