Build Sheet
Old Aug 1, 2007 | 09:14 PM
Raider14A's Avatar
Raider14A
Default Build Sheet
I have a 1997 Ram 2500 Laramie SLT extended cab, 8800 lb variant. I was wondering if there was any way to get an actual build sheet for it. My VIN is 3B7KF23Z0VM505828. Any information would be helpful. Thank you.
Old Aug 1, 2007 | 09:53 PM
Cereal Killer's Avatar
Cereal Killer
Default RE: Build Sheet
You shouldn't put your vin number on the internet. People could get keys for your truck made...
As far as the build sheet,i'm not sureif you've tried yet, buta dodge dealership should be able to give you that.
Old Aug 1, 2007 | 10:36 PM
rhaines00ram's Avatar
rhaines00ram
These guys gave me mine in about 2 days just email them and give them the vin and they will email you a build sheet
customerassist@daimlerchrysler.com
HERES WHAT THEY SENT ME
Desc: 2000 ? DODGE RAM 1500 P/U QUAD CAB
*R1 - Premium Cloth 40/20/40 Bench Seat
-AZ - Agate
ADAP - Light Group
ADJ - Heavy Duty Service Group
AGG - Sport Appearance Group
AHC - Trailer Tow Group
AJKP - Convenience Group
APAS - Monotone Paint
ASPP - SLT Decor Group
A05P - 5.2L Engine(ELF)/4Sp Auto Trans(DGT)
BAZP - 136 Amp Alternator
BCQP - 750 Amp Maintenance Free Battery
BGJS - Pwr Disc/Drum Rr Anti-Lock Brakes
BKAS - 11x2 Rear Drum Brakes
CBEP - 40/20/40 Split Bench Seat
CGDS - Front Height Adjust Shoulder Belts
CGWS - Next Generation Front Air Bags**
CGZS - Passenger Air Bag On/Off Switch
CHEP - Deluxe Headliner
CKEP - Front Seat Area Carpet
CLAP - Front Floor Mats
CSPS - Passenger Assist Handle
CSRP - Passenger Assist Handles
CUDP - Mini Overhead Console
CUE - Rear Underseat Compartment Storage
DGB - All 4-Speed Automatic Transmissions
DGTS - 4-Spd. Automatic 46RE Transmission
DHAP - Lock-Up Torque Converter
DHKS - Shift-on-the-Fly,231HD Transfer Case
DJCS - Dana M44/216MM Front Axle
DMDP - 3.55 Axle Ratio
DRBP - Corporate 9.25 LD Rear Axle
EAAC - All Engines
EAGC - All Gas Engine
ELF - 5.2L V8 MPI Engine
GACS - Tinted Glass Windows
GFD - Rear Sliding Window
GNAS - Rear View Day/Night Mirror
GNMP - Passenger Side Sun Visor w/Mirror
GTSP - Power Heated Mirrors, Fold-Away
GVBC - All Vehicles W/Power Mirrors
HAAP - Air Conditioning
HGAP - Hood Insulation
HGBS - Dash Liner Insulation
JAYS - Instrument Cluster w/Tach
JCBS - 120 MPH Primary Speedometer
JHAS - Var Intermittent Windshield Wipers
JJAS - Cigar Lighter
JJBS - Dual Note Electric Horns
JJJS - 12V Auxiliary Power Outlet
JPBP - Power Locks
JPDP - Power Windows, Driver One-Touch
KKAP - STRIPE/BADGE/MOLDING/COLOR
KRAP - STRIPE/BADGE/MOLDING/COLOR
KTAP - STRIPE/BADGE/MOLDING/COLOR
KWAP - STRIPE/BADGE/MOLDING/COLOR
LBAP - Map/Courtesy Lamp
LBCP - Glove Box Lamp
LDAS - Underhood Lamp
LMAS - Halogen Headlamps
LMEP - Halogen Quad Headlamps
LNJP - Fog Lamps
LPES - Cargo Lamp
MBPP - Body Color Front Bumper
MBQP - Body Color Rear Bumper w/Step Pads
MDAP - Front License Plate Bracket
MFNP - Body Color Grille
MHAS - Black Windshield Moldings
MWDS - Removable Tailgate w/Caliper Latches
NAA - Federal Emissions
NBKP - EVAP Control System
NFWS - 26 Gallon Fuel Tank
NHBP - Auxiliary Transmission Oil Cooler
NHMP - Speed Control
NMCP - Heavy Duty Engine Cooling
PG8A - Forest Green Pearl Coat
QG8S - Forest Green Pearl Coat
RAAC - All Radio Equipped Vehicles
RBN - AM/FM Cass Radio w/Changer Control
RCEP - Infinity Speakers
RDDP - Fixed Long Mast Antenna
SBAS - Power Rack and Pinion Steering
SCVP - Leather Wrapped Steering Wheel
SFBS - Front Heavy Duty Shock Absorbers
SGBS - Rear Heavy Duty Shock Absorbers
SHAS - Front Stabilizer Bar
SUAP - Tilt Steering Column
TBBS - Full Size Spare Tire
TBMP - Tire Carrier Winch
TXWP - P265/75R16 OWL On/Off Road Tires
TZAP - Goodyear Brand Tires
WLBP - Steel Spare Wheel
WMJP - Center Hub
WNDP - 16X7.0 Cast Aluminum Wheels
XBSS - Pickup Box
XCMS - Vendor Painted Cargo Box
XEFP - Transfer Case Skid Plate Shield
YAAS - Build To U S Market Specifications
YEP - Manuf Statement of Origin
YGAA - Without Billable Fuel
ZBSP - Spring - Left Rear
ZHDP - Spring - Left Front
ZPSP - Spring - Right Rear
ZWCP - Spring - Right Front
Z6BS - GVW/Payload Rating
1AAS - U.S. Dealer Retail
132S - Zone 32-New York
2TGA - Customer Preferred Package 2TG
24G - Customer Preferred Package 24G
3VTA - Customer Preferred Discount
4KZS - 4X4 Tracking
4SPA - Supplemental NY Consumer Protection
5A6P - Waterbase Paint
6F5 - Paint Order Code
6USS - Label - U.S. Specifications
633S - New York State Code
933S - New York State Code
Old Aug 2, 2007 | 01:37 AM
ryans590's Avatar
ryans590
here is a link that tells all you need to know about getting a build sheet
https://dodgeforum.com/m_292535/tm.htm
also id remove your vin...mine as well say my visa # is XXXX and the exp date YX/YX while your at it lol
