is it possible to rebuild a pcm?
Old Aug 4, 2007 | 01:19 PM
firealarmguy911's Avatar
firealarmguy911
Default is it possible to rebuild a pcm?
96 dodge ram 1500 4 wheel 5`9 it was never runnin right replaced idle air control valve, egr valve, throttle position sensor< then finally took it to some one with a obd2 to do the diagnostic he says it a bad pcm the connections are loose . is it possible to sodder the connections back together realictcally or is it one of those things that has t be done by some computer autimated assembley line just so i can get to work tomarrow till the new one comes in next weeek?
Old Aug 4, 2007 | 01:25 PM
Fox Fader's Avatar
Fox Fader
Default RE: is it possible to rebuild a pcm?
I'm not sure if I could succinctly say it's worth trying, you don't want to them have the ECU mess up other sensors.
