HYPERTECH caused p0601 code
Old Aug 5, 2007 | 07:27 PM
ddog737374's Avatar
ddog737374
Default HYPERTECH caused p0601 code
well i put my hypertech back on my truck today and right after i installed itthe check engine light came on with a p0601 code so i think the hypertech screwed me over anthing i can do?
Thanks Dan
Old Aug 5, 2007 | 07:58 PM
Fox Fader's Avatar
Fox Fader
Default RE: HYPERTECH caused p0601 code
P0601 (Internal Control Module Memory Checksum error)
Seems as if it (hypertech) didn't take .
Why did you say you put it BACk on?
Old Aug 5, 2007 | 10:45 PM
ddog737374's Avatar
ddog737374
well i took it off for a few weeks agoto see what my i was getting for MPG with out itand i put it back on last night and right away my check engine light came on
Old Aug 5, 2007 | 11:23 PM
Fox Fader's Avatar
Fox Fader
Did you try to load it again?
Old Aug 6, 2007 | 03:08 AM
ddog737374's Avatar
ddog737374
yeaI reloaded it took it off and on about 2 times and it will come on every time
Old Aug 6, 2007 | 10:52 AM
Fox Fader's Avatar
Fox Fader
So it's coming on after you load the Hypert, but the flash IS loading?
Old Aug 6, 2007 | 12:31 PM
ddog737374's Avatar
ddog737374
yea it acts as if nothing is wrong with the truck
Old Aug 6, 2007 | 01:18 PM
froesen's Avatar
froesen
time to call hypertech on that one, i think...
Old Aug 6, 2007 | 01:52 PM
Fox Fader's Avatar
Fox Fader
If it worked before and you didn't have Dodge do a reflash or change any sensors,
I'dcheck to be sure all connections are clean on the HTech and the Ram.
Can you do the HTech flash then clear the code?
Old Aug 6, 2007 | 06:47 PM
ddog737374's Avatar
ddog737374
yep i'v done every thing i took it to a shop and they want 309 buck for a new PCM and im sure hypertech wont pay for anyhting.
