Fuel Saver? You be the Judge.
Old Aug 8, 2007 | 12:34 PM
Fox Fader's Avatar
Fox Fader
Default Fuel Saver? You be the Judge.
http://www.bgprod.com/news5.html
I like their transmission fluids, but this, not needed
if you believe in using www.toptiergas.com
Old Aug 8, 2007 | 01:15 PM
2500 mopar's Avatar
2500 mopar
Default RE: Fuel Saver? You be the Judge.
looks kinda like alcohol to me....duh, higher octane
Old Aug 24, 2007 | 03:01 AM
Slomojo01's Avatar
Slomojo01
blah blah blah... Gas saver my rear end!
Stop buying gas with e85 mixed with it. e85 increases surface tension in fuel making fuel vaporization more difficult plus it only has around 70,000 btu in it while gas has around 130,000 btu. This difference in btu literally dillutes the gas which reduces mileage. Want proof? Ask a Chevy dealer what mileage a flex fuel vehicle gets on gas as opposed to pure e85. Long story short, less mileage with e85. If you can't find fuel without e85, add 2-3 ounces of pure acetone to every 10 gallons of gas in your tank. Acetone will reduce surface tension in your fuel making fuel vaporization less difficult. For 12-13 dollars a gallon for acetone, I'll try that with a scanguage, which measures mileage on 1996 and up vehicles as well as many otherengine details, for a week and return the scanguage after I see the result. If the acetone works, I might just keep the scanguarge and also go around to different high quality gas stations to see who has the fuel that gives the best mileage. Spending $120 as opposed to say $13 is a big difference, and the scanguage will tell you immediately wheter or not it works so whats to lose?
Old Aug 24, 2007 | 03:45 AM
Slomojo01's Avatar
Slomojo01
One More Thing! Acetone will ruin your paint! Use a Great big acetone resistant funnel and proper measurements or else!.
Also, Acetone is not always Pure Acetone!
"Duplicolor" makes the good stuff, Acetone that is, so I've heard... "Klean Strip," Acetone, as they say is 99.5% pure and not dilluted which aint bad, however their msds report says that it's anywhere from 95% to 100% pure which is isn't necessarilly as good as Duplicolor's Acetone which is 100% pure according to their msds report. Pure=Better
On another note, any more than say 3-4 ounces per 10 gallons and Acetone has negative affects on mileage, Don't over do it. try 2 ounces, try 3 ounces try 4, but anymore then that and I don't know what might happen. Be Carefull!
P.S. Acetone works with diesel just like gas. 2-3 ounces per 10 gallons fuel ratio works well especially with a great big acetone resistant funnel.
Old Aug 26, 2007 | 01:45 PM
rabbler's Avatar
rabbler
That demo is a 3 part cleaning system. 1 can is an in tank injector cleaner. 1 is a combustion chamber cleaner and the other is a throttlebody cleaner. they do work but only if you system is dirty. You may restore lost milage but you won't gain anything.
Old Aug 27, 2007 | 07:29 AM
HankL's Avatar
HankL
There is a trade-off after a cylinder/injector cleaner that you can't really predict in advance.
If the cleaner improves the balance of all cylinders for air to fuel ratio
there may be a small MPG increase.
Before the cleaning 2-4 cylinders might be running rich because tarry deposits on the backsides of intake valves may be limiting airflow. After cleaning these cylinders will get more airflow and their afr will get closer to the desired 14.7
On the other hand, carbon deposits inside cylinders raise the 'real world' compression ratio. This actually improves MPG. The build up of carbon deposits inside the cylinder is one of the things that causes an engine to do better as it 'breaks in'
I am believer in using cleaners every so often
but I am not surprised if MPG actually goes down a bit.
Old Dec 23, 2008 | 05:26 AM
fuelsav12's Avatar
fuelsav12
Default Fuel Saver
Hi,
The spiraling costs of fuel prices has driven many car owners to seek alternative solutions that will help them get more miles for their bucks. You can get more information from www.gainex.co.uk/
