Burning brakes
today i noticed a burning smell and narrowed it down to my driver side rear brake. it seems like it is somewhat stuck and is heating up the drum and my wheel really bad. when i parked i could barely touch my wheel without getting burned. i have never used my emergency brake so i dont think that is the problem. just wondering if anyone has experienced this before and what they did. my last truck did the same thing and when i brought it in to get fixed it cost me 70 buck. basically looking for a cheap fix, mabye some parts.
thanks
thanks
Sounds like whoever did the last brake job didnt adjust the rear shoes correctly...........are the shoes locked up against the drum? If so, use a big flat tip screwdriver and backoff the adjuster some.........I'd probably have the drum turned ($15) and put new shoes on ($25)............normally a wheel cylinder wont seize in the outward position, so I would probably leave it alone unless it is blown.......
