quick electric fan wiring question
Those of you that have electric fans, where did you tap into the ignition switched 12V source?I'm wondering where is the best place where I won't overload something...
how are you wirring it? are u using a theromostat or just gonna have the fans on whenever the truck is on, your using a relay right if so can go off of the wiper moter (wires going into the firewalldrivers side right by the hood spring)i dont rember what colour so just test and see what one comes on when u turn on the key
I'm going to run a pusher/puller system. 14" pusher over the A/Cand a 16" puller on therad side.I'mrunning a thermo connector that pushes directly into the rad fins as well as anA/C relay to the A/C clutchto control the 14" pusher. Also have a flex a lite controller that will delay fan start for 6 secto hold back the intial amp pull, and start the fans at 60% and work up form there. Controller system rated at 35 amps, the fans pull a working total of 18. Looking for as clean an install as possible,is there a fuse box in the engine bay I could tap into, or will I need to push a wire through the firewall and connectto the driver's side fuse box in cabin?
