reverse problem
Old Aug 17, 2007 | 06:53 PM
acw592's Avatar
acw592
Default reverse problem
We have a 2000 ram 1500 sport 4x4. 5.2 auto trans., with just over 200k on it. I thought i noticed a few times that it seemed slow to go into reverse after it had sat all night. Today I started it and when I put it into rev. I gave it some gas and it reved like it was in neutral. After a few seconds it engaged and went. I can't say Iv'e noticed this in drive at all, but I usually back out when I leave the house. The guy whom I bought the truck from rebuilt the tranny maybee 2 years ago at the most. The truck only does this after its sat overnight. All shifts are good/firm and if you drive it somewhere and get back in it later it goes into gear fine. Anybody have any ideas? Thanks!
Old Aug 17, 2007 | 10:38 PM
dhvaughan's Avatar
dhvaughan
Default RE: reverse problem
sounds like 'torque convertor drainback' where enough of the fluid drains out to make it slip. mine did that one morning and i thought it had bitten the big one. then never did it again (yet), although when i rechecked the fluid it was about a quart low.
recheck you fluid level - truck hot, in neutral NOT PARK, as pump doesn't pump into tc in park. then in the mornings pull it into neutral for a minute before you take off and see if that helps.
Old Aug 17, 2007 | 10:42 PM
WayneC's Avatar
WayneC
There is a check valve in the cooler line that may be faulty/missing. It prevents above mentioned drain back.
WC
