backfire?
Old Aug 27, 2007 | 12:35 AM
Moparkid032's Avatar
Moparkid032
Default backfire?
ok well i figured i would try to adjust the exhaust..well apparently the popping is coming from where the header meets the block..i look clsely and i can see a lil quick frame townards the end of the header where it meets the block.. now what can cause this? i already check the bolts they were snugged..can it be the gasket? but why would there be flames? i hope nothing serious is wrong
Old Aug 27, 2007 | 02:44 AM
vduncan's Avatar
vduncan
Default RE: backfire?
My friendwas always burning up gaskets on his chevy. It has a standard shift trans so he drives it a bit and then to scare people he shots it off while in gear. He waits a couple second and when he starts it again it makes a giant backfire. he switched to copper gaskets and now cant burn them up
Old Aug 27, 2007 | 07:11 PM
Moparkid032
but it only does it on one section of the header..not the whole thing.. i noticed it does it on the other side to..and the both leak closest to the cab..so can a bad gasket cause this? cause i just put it on about 2 weeks ago...or can it be something else
Old Aug 28, 2007 | 01:22 PM
Socha_62's Avatar
Socha_62
Are they aftermarket headers?
If not its just the gasket thats shot, unless the headers themself are cracked or something. If they are stock I would get some aftermarket ones since its gonna be a PITA to get the stock ones off anyways.
Old Aug 29, 2007 | 06:50 PM
Moparkid032
http://store.summitracing.com/partde...p;autoview=sku
these are the headersi got..my friend was telling me when it came that the gaskets that came with it are P.O.S...so i am hoping the gaskets blew out..the truck is in the shop so i will know tomorrow
