o2 sensor
Old Aug 30, 2007 | 10:47 AM
Fox Fader's Avatar
Fox Fader
Default RE: o2 sensor
save $$ here
www.oxygensensors.com
been using them for 10 years.
Old Aug 30, 2007 | 10:50 AM
rtmorrisjr's Avatar
rtmorrisjr
ORIGINAL: VWandDodge
ORIGINAL: rtmorrisjr
ORIGINAL: Matt Harwood
I've got a persistent P0138 code which means oxygen sensor 2 in bank 1 is too high--does that mean the after-cat sensor? My pre-cat sensor is only 5 months old and it's a dealer piece--surely it isn't going bad yet, right? The fact that it says bank 1 suggests that perhaps there's a sensor on each bank? I haven't crawled under there to have a look, but I'm doing an oil change today and I'll see.
Thats correct. That code is for the o2 sensor after the cat. i have the same code. the light just doesn't bother me enought to spend $75 on the new sensor
It should, because it's telling you something is wrong. Not spending $75 could lead to spending three times as much down the road, where you'll really be bitching.
Treat your truck right and don't be cheap.
So your saying, fix something that only tells you that the cat is not efficant. Or it will not be good on the truck. Funny thing is is that my fathers truck has had the same code since about 60,000 miles. he now has 295,000 on it and guess what, lights still on and no problems. so thats why i say its not a needed fix. I dont see why fixing it will better, or if not fixed, worsen the truck.
Old Aug 30, 2007 | 10:56 AM
rtmorrisjr's Avatar
rtmorrisjr
forgot to mention, unless you have to go through inspection. then you will need to change it
Old Aug 30, 2007 | 11:27 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Oh well. It's your truck.
Old Aug 30, 2007 | 03:05 PM
rtmorrisjr's Avatar
rtmorrisjr
Im just wondering what it hurts. if it does affect something please tell me...i've always been under the impression that it didn't affect anything. if people tell me otherwise i will change it tomorrow. Just dont see the reason to change it if its not affecting anything else. But am i wrong? Can you enlighten me to what it is affecting...besides the CEL.
Old Aug 30, 2007 | 03:17 PM
Fox Fader's Avatar
Fox Fader
If I'm right, those two O2's is where the PCM also get's it's proper fuel trim.
Old Aug 30, 2007 | 03:26 PM
rtmorrisjr's Avatar
rtmorrisjr
i thought that only the 1st o2 sensor was for the fuel mixture. [sm=confused06.gif]
Old Aug 30, 2007 | 03:47 PM
Fox Fader's Avatar
Fox Fader
Fuel trims are used as a 'modifier' to the fuel map lookups to get the A/F Ratio at part throttle (closed loop) to where the ECU wants it. They are not used in open loop mode.
O2 values and trims are ignored during open loop mode. The ECU uses a preset amount of fuel, ignoring any trim corrections. O2 Volts will not cycle in open loop mode.
Old Sep 1, 2007 | 02:52 PM
dishdude2k's Avatar
dishdude2k
yall say it wont hurt the truck just cause the c/e light is on.. that may be.. it DOES affect your fuel consumption.. its there for a reason... the other concern would be this.. what happens when something ELSE goes wrong with the truck.. and it throws a code... you wont even know it threw a code.. the light is already on.. lotta good thats gonna do.. it defeats the whole purpose of having a c/e light ... FIX IT
dishdude2k's Avatar
dishdude2k
btw.. results of the original post i started... i replaced the front o2 sensor.. the truck runs like a dream.. no c/e light
