Alternator?
Old Aug 29, 2007 | 06:48 PM
bondman35a's Avatar
bondman35a
Default Alternator?
When i drive i have started to notice that the voltmeter starts to drop and then rise. There isn't that much of a drop but i can tell looking at the gauge. I have a digitial voltmeter on my fuse block for my amp so i can see what the actual value is at idle its around 13.6 or 13.7. I can't really see what it is when driving because the digital readout is located behind the driver seat, although i did look back once and it read around 14.0 volts. Also i hooked my plow up the other day with the new batteries and it did take awhile for the voltage to come back up after moving the plow around. Both batteries are like a month old. I have had the truck for 25k and havn't done anything with the alternator. So is my alternator on the way out? or could it be somehting eles? thanks in advance
Old Aug 29, 2007 | 08:05 PM
dishdude2k's Avatar
dishdude2k
Default RE: Alternator?
sounds to me like its on its way out.. might wnat to see if you can put a higher amp alt. in it if your running all that equipment.
Old Aug 29, 2007 | 10:24 PM
bondman35a's Avatar
bondman35a
ok i checked the belt today and it is tight and good. i'll take it off and have it tested. thanks
Old Aug 30, 2007 | 05:49 AM
steve05ram360's Avatar
steve05ram360
you might want to check into swapping the alt for the 135 amp jeep GC one... it sounds like your's is going out.
Old Aug 30, 2007 | 11:19 AM
bondman35a's Avatar
bondman35a
Will that g.c. fit right in? I thought the stock one for the ram was like 130 amps so would it even be worth it?
Old Aug 30, 2007 | 11:28 AM
steve05ram360
I believe it is a drop in swap... do the research to verify. I never needed to swap mine in my 2000 ram so I dont know 1st hand which year will drop in. Physiclly they are all mounted the same, the connector on the back may be different and that is one thing you'll need to verify.
