more power with muffler or no muffler?
Old Sep 3, 2007 | 04:29 PM
  #21
mopowar's Avatar
mopowar
Default RE: more power with muffler or no muffler?
Basically the idea is this:
When the exhaust gas first leaves the heads, it is very hot and expansive. As it moves through the exhaust system it cools and contracts. The pipes should be sized to accomodate this contraction so the gas doesn't lose velocity. This is all well and good up to a point. Namely the first restriction in the system- whether it be a cat or muffler. With the factory system, you have very good flowing exhaust manifolds that go into a tiny and ill bent Y pipe that then dumps into a 3" pipe right before a very restrictive cat. Backpressure indeed. It is set up this way so that the catalytic converter will reach operating temperature (light off) very quickly.
Old Sep 3, 2007 | 10:57 PM
  #22
spaz_22's Avatar
spaz_22
thus that's why i said he will lose low end
Old Sep 4, 2007 | 07:41 AM
  #23
mopowar's Avatar
mopowar
Thus why I said:
Spazz brings up a good point that I keep missing. If you intend to use the factory Y, none of this applies. He istotally correct in saying that opening things up on both sides of the factoryY will cancel out the scavenging effects.
Old Sep 4, 2007 | 02:02 PM
  #24
IndyRamMan's Avatar
IndyRamMan
LOL at bouncer and mopower. I love benchracing. Bench dynos are even funnier. I have to add to this and say its all dependant upon the setup, and you really cant tell unless you actually try it (or you know the formulas and variables to input). In my personal experience my torque was greater ever so slightly when I had open headers, but the top end died horribly. With my exhaust on it pulls well down low, and like an ls1 up top. The 360 motor is quickly becoming my favorite motor for a multitude of reasons.
