Window Question
Old Sep 11, 2007 | 11:08 AM
DuranguenzeRam's Avatar
DuranguenzeRam
Default Window Question
Recently my truck driver side window switch seems to be acting up. sometimes it will work fine up down then others seems like no power. I am able when no power to move the window up and down while holding the button then it starts working . I was thinking switch but everything else works fine, would greasing the rollers help? Any help would be appreciated. Also to repair do i have to take the whole panel apart? if i have to might as well fiddle with the speakers lol.
Old Sep 11, 2007 | 11:18 AM
dishdude2k's Avatar
dishdude2k
Default RE: Window Question
its the window motor... its a dodge thing.. i have replaced literally hundreds of them.. my van does it.. my truck b4 that did it.. have ALOT of them come into the shop with the same thing.. do this.. next time it stops working... open the door.. hold the switch in the up or down.. and slam the door hard.. bet it starts working... all it needs is a motor..
Old Sep 11, 2007 | 12:40 PM
rtmorrisjr's Avatar
rtmorrisjr
While your in there replacing the motor, it wouldn't hurt to greae up the rollers.
Old Sep 11, 2007 | 01:23 PM
sony224422's Avatar
sony224422
its my switch for me. The locks work, and the pass side switch works. But the driver side doesn't sometimes. Then i figured out when i popped out the switch that it will work fine while its not in. Or if i slide it up so theres no pressure on the wires it works.
Old Sep 12, 2007 | 02:25 PM
DuranguenzeRam
Thanks for all your help gonna take the switch out and see waht i could do also speaker time see what i fit in there. Appreciate all the help!!!
