Crank position sensor problem...
Old Sep 15, 2007 | 10:07 AM
motorbrreath's Avatar
motorbrreath
Default RE: Crank position sensor problem...
ORIGINAL: aim4squirrels
Yeah, I kind of have these Popeye sort of forearms that have gotten in my way more than once working on the truck.
i have the same problem, i hate gettin my forearms stuck in every crevas.
Old Dec 1, 2007 | 01:29 PM
niqherby's Avatar
niqherby
I have a 1995 5.2 and i was wondering if on my truck the cps if i slotted it would that work or is my truck old enough taht i can just turn the distibutor to advance the timing?? i was wanting to work on it this afternoon so any help is appreciated. thanx
Old Dec 1, 2007 | 01:33 PM
turkeyhunter1962's Avatar
turkeyhunter1962
Turning the distributor will only cause you fuel sync problems and not advance the timing. What the mod will do is advance your timing. Leave your distributor where it is.
Old Dec 1, 2007 | 01:39 PM
niqherby's Avatar
niqherby
alright thanx. so i take out the bracket holding the cps and just take a file and file away? file to the edge? how far? and then i slide it towards the oil filter to adavance right?
Old Dec 1, 2007 | 02:39 PM
2500 mopar's Avatar
2500 mopar
what is the benefit of this mod? and as far as the tps mod which direction do you rotate the sensor towards the radiator or towards the firewall? thanks
