Vacuum Problem??
Old Sep 18, 2007 | 10:36 PM
Wilks's Avatar
Wilks
Default Vacuum Problem??
I have a 97 4x4 318 auto. When I accelerate my heater vents change from the settingI have it on. Then when the RPMs comeback down itgoes to the correct setting. I've looked for a vacuum leak but can't find one. It also went through a fazeof revving when I started it, to about 1200 rpm then down. More thanusual.Any reason for thevacuum problem.
Old Sep 18, 2007 | 11:21 PM
priest1981's Avatar
priest1981
Default RE: Vacuum Problem??
There should be check valves inhe vacuum lines going in to your bulkhead, these usually go bad causing the problem you are describing.
Will
Old Sep 18, 2007 | 11:22 PM
Wilks's Avatar
Wilks
Thank you
Old Sep 19, 2007 | 08:20 AM
IndyRamMan's Avatar
IndyRamMan
mine does that too, Iv just delt with it figguring it was a ram design flaw.
Old Sep 19, 2007 | 08:31 AM
BradBeyer's Avatar
BradBeyer
I installed the check valves and it seems to have fixed my problem...so far
TSB:
http://dodgeram.info/tsb/1996/24-01-96a.htm
Brad
