my programmer
Old Sep 21, 2007 | 03:58 PM
brandonlee07's Avatar
brandonlee07
Default my programmer
i just bought a programmer from a friend of mine with the same engine/truck as me so the programmer will wok for my truck i was just wondering if there was a easier way to reset the VIN thats saved on it so i can use it for my truck than sending it back to hypertech can anyone help me out here?
Old Sep 21, 2007 | 04:21 PM
Ramdamit98's Avatar
Ramdamit98
Default RE: my programmer
If the truck it was used on before hasbeen programmed back to stock then the programmer can be used on another truck. The programmers are designed to be used on one vehicle at a time (VIN locked) but once its returned back to stock then it's unlockedandit can be used on a different vehicle and will be VIN locked to that one until it's returned back to stock.
Old Sep 21, 2007 | 05:57 PM
Socha_62's Avatar
Socha_62
Yeah, you and your buddy can't use it at the same time. He has to set his truck back to normal for you to be able to use it...
Old Sep 21, 2007 | 06:17 PM
brandonlee07
yea one problem is he wrecked his truck and theres no way to get it outta vin lock that way is there another way i could possibly do it?
Old Sep 21, 2007 | 06:37 PM
aim4squirrels's Avatar
aim4squirrels
Hypertech will have to reprogram it. Currently you have your buddy's old stock program sitting in the hypertechand that wouldn't do you any good even if you could put it on.
Old Sep 21, 2007 | 07:30 PM
WayneC's Avatar
WayneC
[sm=lockeddance.gif]
[sm=laughat.gif]
BUSTED!
Old Sep 22, 2007 | 07:49 PM
pcfixerpro's Avatar
pcfixerpro
If he wrecked his truck, steal his computer for a bit,put it in your truck, use hypertech 2 remove the software. plug in your computer again and upload the firmware. then give him his computer back. Otherwise, you just bought a paper weight...
Old Sep 22, 2007 | 08:20 PM
aim4squirrels
I'm sure the truck is probably spare parts at this point.
But look on the bright side, some salvage yard is running around with a perfectly good hypertech flash!
