radiator leak
Old Sep 24, 2007 | 03:24 PM
marionso14's Avatar
marionso14
Default radiator leak
so i noticed some water leaking from the radiator of my 00 ram 5.2the other day and checked it out. sure enough it was low. i filled it back up and drove it nice and easy and it stayed full. however if i drive it kinda hard it will leak more. i thought about using some sort ofradiator stop leak, but i have been told that it will clog up the radiator. any thoughts on this? any particular kind to get, or avoid? if that doesnt help, roughlyabout how much should a new radiator and install. cost.
Old Sep 24, 2007 | 05:25 PM
2500 mopar's Avatar
2500 mopar
Default RE: radiator leak
my heater core blew, i used the radiator stop leak and it didnt help, or hurt, the hole in the heater core must be too big
i used the stop leak and had to trouble with clogs
Old Sep 24, 2007 | 09:30 PM
EricCartman's Avatar
EricCartman
It's better to change a radiator than fill it with stop leak... I know because I tried stop leak - and it only made the problem worse. I suspect that it plugged some of the tubes in the radiator - and the truck was just running up the temp scale and never really leveled off or cooled down. I finally found the leak when I hooked up a prestone back flush kit...
Yeah... it's not a Dodge, but a cooling system is a cooling system.
If you have a shop do a repair... it can be spendy. However, if you are mechanically inclined, you should be able to perfrom the repair yourself and save some money. You'd be suprised how cheap you can find a decent radiator. Try someplace like Radiator.com or RadiatorBarn.com. I looked up the cost for a 2001 1500 w/ 5.9 and AC... 166 delivered. When I got a radiator for my Toyota - it was 150 bucks delivered - and that was for an all brass/copper radiator. The cheapest one I could find locally was plastic and aluminum for 190.
If you do go through radiator.com- just be forewarned that when you think you are talking to a tech - you are actually dealing with a computer script. Type this question - are you a person? and it will give you a $20 discount coupon code. I ended up going with RadiatorBarn for my specific application because they had a better radiator at a lower price.
I think the generic going rate for mechanic labor is about 80/hour. You should plan on 2-3 hours of labor on top of that if you go to a shop. Not sure if they will use your part, or if they will force you to buy from them...
Good luck!
Good luck!
Cartman
Old Sep 24, 2007 | 11:39 PM
marionso14's Avatar
marionso14
thanks cartman! i think i will try thatcause i figured it cost some change to have someone else put it in.
Old Sep 25, 2007 | 02:19 AM
habeba86's Avatar
habeba86
If it ever starts leakin when your driving you can put an egg white in there and it should make it stop leakin for a bit.
