rear dif is leaking
Old Sep 26, 2007 | 06:14 PM
timwag2001's Avatar
timwag2001
Default rear dif is leaking
my dif is leaking where my driveshaft bolts onto the (yoke?) thing that sticks out of the diff.
how bad is this and is it easily fixed?
Old Sep 26, 2007 | 06:19 PM
Bouncer88's Avatar
Bouncer88
Default RE: rear dif is leaking
It really isn't that bad, you need a pinion seal. As far as installation and removal goes it shouldn't be too hard, you have to take off that huge nut/bolt on the side of the pumpkin where the drive shaft bolts up to and get a seal puller and pull it out or you could pull it out with needle nose pliers too.
Old Sep 26, 2007 | 09:21 PM
timwag2001's Avatar
timwag2001
thanks for the reply... i appreciate it.
Old Sep 26, 2007 | 11:04 PM
DONNYO's Avatar
DONNYO
JUST MAKE SURE WHEN YOU TIGHTEN THE PINION NUT BACK UP YOU HAVE THE CORRECT PRE LOAD,IF NOT YOU WILL HAVE A PROBLEM.
Old Sep 27, 2007 | 01:33 AM
rabbler's Avatar
rabbler
Mark the position of the nut in relation to the pinion threads before you remove it.
Reinstall the nut and tighten untill the marks line up. don't over tighten!
Old Sep 27, 2007 | 11:12 AM
BLKbeast's Avatar
BLKbeast
hope that just the seal is bad! in my case i had a leak from the seal but not becasue the seal was bad but my front pinion bearing was shredded and my pinion was floating off the ring causeing the pinion seal to break. all kinds of metal shavings in my diff caused pitting of the spider gears and ring gear. tranny shop wanted 1600 to fix it. i decided im just going to replace the whole rear end from a pick n pull for half this price
Old Sep 27, 2007 | 11:23 AM
Bouncer88's Avatar
Bouncer88
ORIGINAL: BLKbeast
Ouch, I did the same thing, I went and pulled a rear end assembly. It was better that way because I redid the brakes completely, put some new axles in, and I am currently waiting a week or two before I order my locker and 3.92's or 4.10's to throw in there.
