how much tranny fluid?
Old Sep 27, 2007 | 06:02 PM
motorbrreath's Avatar
motorbrreath
Default how much tranny fluid?
how much tranny fluid does a stock pan hold?
Old Sep 27, 2007 | 06:08 PM
motorbrreath
Default RE: how much tranny fluid?
nevermind, found it. 6-7 right?
Old Sep 27, 2007 | 06:13 PM
Bouncer88's Avatar
Bouncer88
ORIGINAL: motorbrreath
If all the fluid is drained from the transmission then 10 quarts is the overhaul fill specification, for you I would say about 5-7.
Old Sep 27, 2007 | 07:43 PM
heybuddy1901's Avatar
heybuddy1901
i put 5 in and im right in the center..
remember to check it in neutral, haha
Old Sep 27, 2007 | 07:53 PM
Bouncer88's Avatar
Bouncer88
ORIGINAL: heybuddy1901
What I usually do is run it through every gear for ten seconds then check the dipstick, but I guess neutral works too
Old Sep 27, 2007 | 08:18 PM
heybuddy1901
ORIGINAL: Bouncer88
well i was assuming that you did that before, haha
yeah just get it warm, every gear.
drive, neutral, reverse, neutral, drive, neutral, etc.
until u feel good about it, just remember to check it in neutral..
cause if u check it in park the reading is going to be higher..
Old Sep 27, 2007 | 08:54 PM
motorbrreath
appreciate it guys. i had someone do this pan gasket before and he overfilled the hell out of it. so bad the tranny wouldnt shift out of first... thats why i did it my self.
Old Sep 27, 2007 | 09:12 PM
aim4squirrels's Avatar
aim4squirrels
Actually, there's an optimum fill curve in the service manual based on engine temp. I try to follow that as best as possible.
Motorbrreath:
If you're going to pull the tranny pan and you haven't done it yet, put a piggy back type plug in the thing. It makes it unbelieveably easy to change the fluid and pull the pan. I put my plug on the back passenger's side of the pan just above where the magnet is. I put it in the side of the pan not the bottomso I don't ever have to worry about catching it on something. Put a little RTV between the washers and the pan for a good seal and you're good to go.
Old Sep 27, 2007 | 09:21 PM
padodgeram's Avatar
padodgeram
check it hot and in N , another easy way to drain out the trans fluid is pop the line off ...
Old Sep 28, 2007 | 01:25 AM
heybuddy1901
yay for having lifts at school
and your lucky that your tq. convert. isnt fubared..
its common when they get over-filled to go south.. did it on my friends jeep, he put way too much ATF in it..
