front brake question
Old Sep 28, 2007 | 05:12 PM
tazman6789's Avatar
tazman6789
Default front brake question
Should my front brakes be rubbing when the truck is on the lift? if i spin the front tires i can hear the front pads rubbing on the disc... is this normal? and its both front tires.... for adjusting the rears i see the adjuster holes.. how do i know when they are tight enough? should i hear them scrape just a lil bit? i have no idea how to tell
Old Sep 28, 2007 | 05:18 PM
Bouncer88's Avatar
Bouncer88
Default RE: front brake question
To the rear brake question- it really comes with experience and over all feel of them, when tightening or loosening just spin the drum around and feel where you think it is good, I know I explained it vaguely but it really is all about the feel.
Old Sep 28, 2007 | 05:26 PM
tazman6789's Avatar
tazman6789
should i just barely feel them touching? causei can hear them scrape a bit but not resisting
... i think the fronts might be froze there stiff
Old Sep 28, 2007 | 09:15 PM
XXL 1500's Avatar
XXL 1500
have them in the middle of sound beginning and the start of resistance
you want them making a little contact
adjust some, and then check your parking brake
front brake pads are okay to touch, but not alot of resistance, if there is, you might have some brake caliper hardware binding up on the slides, take out the slide bolts and lube them up with some high-temp lubeeeee
just the bolts themselves, dont grease up the actual slides - doing so will just cause probs in the future with dirt gathering up on the slides and once again binding them up and sticking...
you want them clean
Old Sep 29, 2007 | 12:12 AM
dhvaughan's Avatar
dhvaughan
all that ^^.
normal for front to scrape a little, but should turn easily.
i like to adjust rears up while turning the wheel, till they get tight, and then back them off a little. same as front - a light scrape, but turns easily.
Old Sep 29, 2007 | 12:35 AM
steve05ram360's Avatar
steve05ram360
I use wheel bearing grease on the slider pins... never have had a problem with them after I put it back together (been doing it that way for about 20 years now)
Old Sep 29, 2007 | 10:50 AM
tazman6789's Avatar
tazman6789
took them all apart greased up the sliders, cleaned the rust up on all the brackets put anti seaze on the outside metal edge that slides on the bracket... and its like new brakes again.... today shall be adjusting the rears... thanks guys
Old Oct 2, 2007 | 04:19 AM
steve05ram360
glad to hear it worked for you, how did the backs work out?
Old Oct 2, 2007 | 04:14 PM
tazman6789's Avatar
tazman6789
worked out good, ended up taking the drum off just to double check everything was ok in there. readjusted and its like having brakes again lol
