fuel line repair
Old Oct 4, 2007 | 08:13 PM
redhotram's Avatar
redhotram
Default fuel line repair
Hello i have a 95 ram 1500 5.9 that the fuel pump went out on and in changing it the tank slid off the jack and broke a line off the one with the quick disconnect. is there a repair kit for these?
thanks
Old Oct 4, 2007 | 09:53 PM
dhvaughan's Avatar
dhvaughan
Default RE: fuel line repair
i've never had mine off, so i can't say for sure what you're looking at... but if you're talking about a 3/16 or 1/4 or so steel line that is damaged, then yes - you can buy a double compression fitting. check local autoparts store. its for joining 2 clean cut, non-flared lines, and uses little ferrules (beads) that slide up on the line. should not cost more than $5 or so.
edit... i used one on my boat gas line.
