Metal in the rear diff..
Old Oct 6, 2007 | 12:30 PM
Aircates's Avatar
Aircates
Default Metal in the rear diff..
Ok, I need some help. I pulled my rear diff cover plate to change the oil out and found large pieces of metal stuck to the magnet. They are not gear teeth. one piece appears to have been like a little hollow tube about an inch long and 1/2 inch in diameter. This rear end is in a 2000 Dodge 1500 2wdwith a 5.9liter. It is a 3.92 rear end and does have the LSD because I can see what appears to be little clutch packs on each axle shaft. Something also appears to be wearing away the side gear bearing cap on the passenger side. If someone has a picture of the rear end parts breakout I can point it out and then I need advice on where to get replacement parts. I get the feeling they are going to be dealer only. If that is the case then who is the best dealer to get them from... Thanks for you help...[&o]
Old Oct 6, 2007 | 03:17 PM
froesen's Avatar
froesen
Default RE: Metal in the rear diff..
those are the little retainers that sit in the diff case, part of the lsd, had t hat happen on mine too....posi on mine came appart and took out a ring gear! put something else in there, factory LSD's suck!
Old Oct 6, 2007 | 06:52 PM
aim4squirrels's Avatar
aim4squirrels
Your clutch pack has broken up. It happened to me in July. You can buy a new clutch pack for about $70, but it won't make the posi unit any stronger.
The best two options IMO are the Detriot Trutrac or the Auburn LSD. I went with the Trutrac as it works on a gear system so it has no clutches to wear down or break up.
PORC carries one for the Chrysler 9 1/4 axle for $489.99 and you can probably get it installed for $250. That's a lot cheaper than replacing an axle if the old posi unit breaks up further and causes an axle failure.
Old Oct 6, 2007 | 09:40 PM
XXL 1500's Avatar
XXL 1500
yes affirmitive - factory trac-lok sucks
i have done sooo many re-builds on them for the little retainers on the clutch packs that just kinda pop out
aftermarket replacement recommended
+1
Old Oct 6, 2007 | 09:48 PM
XXL 1500's Avatar
XXL 1500
number 6 is the retainer
from DaimlerChrysler
Old Oct 6, 2007 | 10:04 PM
Aircates's Avatar
Aircates
Yeah that looks like what I found.... Where is the best place to get an aftermarket replacement for it?
Old Oct 6, 2007 | 10:09 PM
aim4squirrels
Try PORC (Performance Off Road Center), summitracing.com, DTS (Drivetrain Specialists), 4wheelparts.com.
That'll get you started at least.
Old Oct 6, 2007 | 10:16 PM
XXL 1500's Avatar
XXL 1500
saw a couple at jegs
im not sure of where there is a wide selection of diffs
Old Oct 6, 2007 | 11:20 PM
Aircates's Avatar
Aircates
I really appreciate all the help. I think I am going to go with an Auburn L/S set-up from DTS. This has been a great site for info. So far everything that I have read has applied to my truck. From the leaking plenum( did that last week), to this problem. I also looked for the rusted rear brake line and, sure enough, that baby looks like it is about to explode. Oh well, I still like my truck. I was raised around Dodges and for better or worse, I will always own one. Again, thanks for all the help...
