Metal in the Diff. Part 2
Old Oct 7, 2007 | 03:26 PM
Aircates's Avatar
Aircates
Default Metal in the Diff. Part 2
Ok... I have the trac-loc out. The retainers on the driver's side were the ones that I found laying on the magnet in the bottom. The retainers that were on the passenger side are also broken but they stayed in the carrier and ended up grinding a groove in the passenger side bearing cap. The groove is about an 1/8 of an inch deep. My question is this; Should I just dress the bearing cap and remove the sharp edges or can I get another bearing cap? I am thinking that the bearing caps are machined to theaxle housing and that they are a matched set. In which case I guess I will just dress them and go.... Does anybody know for sure?.........
Old Oct 7, 2007 | 05:05 PM
Socha_62's Avatar
Socha_62
Default RE: Metal in the Diff. Part 2
By bearing cap do you mean outer race?
Old Oct 7, 2007 | 09:03 PM
rabbler's Avatar
rabbler
I think he means the caps the holds the carrier in the housing.
Just clean it up it should be fine as long as it isn't cracked.
Old Oct 7, 2007 | 09:32 PM
Aircates's Avatar
Aircates
Ok thanks.... When I get to the shop tomorrow I will check it for cracks and then dress it....
