MSD coil question
Old Oct 10, 2007 | 12:36 PM
apiske148's Avatar
apiske148
Default MSD coil question
I have a MSD ignition system and blaster coil, i was wondering where i can find a coili wire or adapter so that a regular coil wire fits on it, right now it is just astripped coil wire shoved in there....(how i got the truck, iwant it fixed!) any ideas short of buying a whole new wire set (i have brand new wires on it already)
Old Oct 10, 2007 | 03:31 PM
padodgeram's Avatar
padodgeram
Default RE: MSD coil question
stock wire to fit the msd coil ? the stock plug to fit the msd coil ? or what here ...summit has a plug kit its a accel ...and ebay has them to msd wire kit... need year of this truck , part number from the coil is it a stock replacement ? msd coil 8228 ? then we will get you all set up !!
Old Oct 10, 2007 | 05:12 PM
steve05ram360's Avatar
steve05ram360
you need the right boot & crimp connection for that setup, as PA mentioned... if you get the msd wire set it will have both in it. it is also the prefered wire set IMO...
Old Oct 10, 2007 | 06:07 PM
apiske148's Avatar
apiske148
i need the wire to go from the msd blaster coil to the stock distributor, its for a 94 ram 1500 5.2L
Old Oct 10, 2007 | 06:11 PM
steve05ram360
I dont think they sell it separately, you may be able to find someone who has bulk wire that you can make your own. it's not to hard if you buy the right crimp tool... ($10 bux or so)
