Installing timing chain at 4* advanced
Old Oct 10, 2007 | 01:41 PM
IndyRamMan's Avatar
IndyRamMan
Default Installing timing chain at 4* advanced
When installing a new chain at 0* you set the #6 at tdc, so when I put the chain on with the crank gear set for 4* advanced, do I rotate the crank so that the 4*+ mark is pointing at the cam mark? or do i rotate the cam to match the crank?
Old Oct 10, 2007 | 01:57 PM
IndyRamMan's Avatar
IndyRamMan
Default RE: Installing timing chain at 4* advanced
nm, i figgured it out
though, any heads up on torque specs would be nice.
