does anyone know why?
Old Oct 11, 2007 | 12:19 AM
shott8283's Avatar
shott8283
Default does anyone know why?
i looked in the FSM and i couldnt find an explination.. hopin some of my mopar brethren could add some insight
why in the hell does the A/C compressor run when you select defrost? normally it wouldnt matter but my e-fan is wired to kick on when the a/c clutch kicks on so i have air movement during A/C operations... defenatly not needed during defrost and cold NY mornings
thanks!
Old Oct 11, 2007 | 12:25 AM
rabbler's Avatar
rabbler
Default RE: does anyone know why?
Here it comes...are ya ready for it?
A/C doesn't just make the air cold it also removes humidity. When you select defrost it engages the A/C so you don't get condensation on the inside of your windshield.
Old Oct 11, 2007 | 12:27 AM
padodgeram's Avatar
padodgeram
A/C you cannot shut off the compressor on defrost. In fact it's designed so that the compressor cuts in to provide air that is free of humidity so that it won't fog up the windshield. damnit !!! to slow...
Old Oct 11, 2007 | 12:34 AM
rabbler's Avatar
rabbler
Sorry
Old Oct 11, 2007 | 03:00 PM
mopar crazy's Avatar
mopar crazy
So would this be the reason why I see water drips from the A/C unit under the hood when I have the temperature dial set towards the blue (cool) but not actually ingaging the A/C button or is there another issue I may experiancing?
Old Oct 12, 2007 | 10:20 AM
shott8283's Avatar
shott8283
thanks guys
Old Oct 12, 2007 | 10:29 AM
Bouncer88's Avatar
Bouncer88
A lot of people laugh when I tell them Air Conditioning is meant to take humidity out of the air, they only think it is made to keep people cool, but when you look at the words in bold text , it says nothing about keeping you cool, only about conditioning the air.
Old Oct 12, 2007 | 10:38 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Eh, that's part of the answer. If the A/C is not cycled on a regular basis, then the seals will dry out. It is also better to use a mix of air, rather than straight hot air inside of the vehicle, so this helps to compensate for it. My 2002 Cavalier is set up the same way.
Old Oct 12, 2007 | 10:44 AM
farva's Avatar
farva
Also at a certain tempurature ( 55-50 degree F) outside temp the A/C should kick off since the A/C can help out any more than the outside air. Up here in North Dakota here when its -40 air temp(not wind chill) the A/C is off and well from that certain temp to there they have have the A/C off. If you are askin how it does it, its by a thermostat designed for outside temp. Anyway hope that helps. I am outta here to celebrate the bday.
-Farva
