Transmission
Old Oct 12, 2007 | 12:44 PM
Dtruck96's Avatar
Dtruck96
Default Transmission
I have a 96 ram 2500 4x4 with a 360. I keep having this problem with my tranny where it shifts great from 1st to 2nd, but 2nd to 3rd it wont shift until I let off the gas. And no I'm not gunning it. Even with slow steady pressure it wont shift until I release the gas and then it shifts hard. Then will drop into overdrive at about 45 mph which makes my truck seriously lag. Anyone have any ideas. I checked the fluid and its full. Thanks.
P.S. Just hit 100,000 miles
Old Oct 12, 2007 | 07:50 PM
Bigdodge98's Avatar
Bigdodge98
Default RE: Transmission
sounds like you need to have your tranny rebuilt to me hopefully its just something little though have you been hard on the truck its whole life?
Old Oct 12, 2007 | 08:29 PM
rabbler's Avatar
rabbler
Check your throttle valve cable adjustment at the throttle body. Pop off the end of the cable at the throttle body it should line up with the stud.
Old Oct 12, 2007 | 11:06 PM
cnybill's Avatar
cnybill
When was the last time you had a tranny service and had the bands adjusted? I have a '95 2500and had a similar problem with the 1-2 shift. After I changed the tranny filter, adjusted the low-reverse band, and added 5 quatrs of newATF+4 fluid it now shifts fine.
