High transmission Fluid
Old Oct 13, 2007 | 03:13 PM
specialist484's Avatar
specialist484
Default High transmission Fluid
i just bought a beautiful 2001 dodge magnum 5.9L. It is really clean, but i keep getting code P1740. The tranny works well with no signs of problems. I checked the fluid level and it was quite a bit over the max. This is probably causing foam and maybe the error code. Just in-case, I got that vavle body cover for the Transmission in the TSB, and am going to installit tomarrow. Wouldtoo much ATF+4 fluid cause the code?
Old Oct 13, 2007 | 03:24 PM
dhvaughan's Avatar
dhvaughan
Default RE: High transmission Fluid
i don't know. make sure you're checking the level with trans warm and in neutral, not park. it will read high in park.
see this.. http://dodgeram.info/tsb/2000/21-11-00.htm
Old Oct 13, 2007 | 04:15 PM
badram1500's Avatar
badram1500
also check your transfer case fluid level. I have seen the seals between the two go bad and one fills the other. Trans filling the t-case not so bad, t-case filling the trans = no lube in t-case and lots of $$$$$$$$$$$$$$$$$$$$$$$$ in repairs
