torque specs 95 ram 5.2
Old Oct 14, 2007 | 05:16 PM
Ramafication's Avatar
Ramafication
Default torque specs 95 ram 5.2
hey guys i put this in the general tech but i figured this might be a bit better, im looking for the torque specs of a 95 318 magnum, i mainly need the connecting rod specs but if anyone has the whole engine spec list that would be great. thanks in advance
Old Oct 14, 2007 | 06:07 PM
XXL 1500's Avatar
XXL 1500
Default RE: torque specs 95 ram 5.2
specs are for a 96
should be same
Install rod caps. Be sure connecting rod, connecting rod cap and cylinder bore number are the same. Install nuts on cleaned and oiled rod bolts and tighten nuts to 61 N·m (45 ft. lbs.) torque
Old Oct 14, 2007 | 06:17 PM
XXL 1500's Avatar
XXL 1500
copyright DaimlerChrysler
Old Oct 15, 2007 | 12:09 AM
Ramafication
thanks alot this is great, lol you wouldnt happen to know the bearing clearance should be do you?
