squeaky rear end
Old Oct 15, 2007 | 02:57 PM
Eric334's Avatar
Eric334
Default squeaky rear end
Got a 2000 ram 4x4 with about 64000 miles on it. I have a squeaking noice that seems to be coming from where the drive shaft goes into the rearend. Does anyone know what this might be? Could my fluid be low, I have not signs of a leak.
Old Oct 15, 2007 | 06:51 PM
rabbler's Avatar
rabbler
Default RE: squeaky rear end
Probably a dry u-joint, factory ones can't be greased. Look for a rusty stain or powder where the u-joint caps meet the cross. If you see it they're done.
I've also seen a few dry pinion seals. Carefully pull back the lip or the seal and spray some lube in there.
Lithium grease works best IMHO.
Old Oct 15, 2007 | 06:57 PM
dhvaughan's Avatar
dhvaughan
sounds like u-joint. mine started with a squeak and i ignored it for a few days. then it began to vibrate and when i checked it the seal and all the needle bearings were gone and the cross was flopping around in the cup. to check it get on level ground, in neutral, all pressure off driveline. grab drive shaft and try to wiggle it back and forth against the yoke. should be zero play.
Old Oct 15, 2007 | 11:50 PM
bill022572's Avatar
bill022572
from your description : definately U-Joint. Like dhvaughan said : check it for any play. If it's just started making noise, you may not feel it yet. But if it's dry, it will eat the needle bearings up quickly.
