whos using EBC greenstuff ceramics?
Old Oct 18, 2007 | 06:17 AM
shott8283's Avatar
shott8283
Default whos using EBC greenstuff ceramics?
i put on a st of EBC greenstuf ceramics about a year ago and they are already needed to be changed out...
was wondering if anyone else is having the same problem..
thanks!
Old Oct 18, 2007 | 08:01 AM
DevilsReject's Avatar
DevilsReject
Noob Assassin
Default RE: whos using EBC greenstuff ceramics?
That doesnt sound right to me.......did you replace your rotors when you installed them?
Old Oct 18, 2007 | 11:35 AM
dillonjm's Avatar
dillonjm
Beyond the previous question, it would also help to know the number of miles on the. A year can mean anything from < 10k to 25k+ depending on how far you drive your truck.
Old Oct 18, 2007 | 12:42 PM
theshocker's Avatar
theshocker
ORIGINAL: shott8283
thanks!
Yeah I did. And yes for the hype and $$ for these pads they did not last too long. They also didn't perform like I thought they would. I have a set of satifies pro ceramic pads now and they are just as good if not better than the EBC's. I just recently put a set of powerslot rotors on and I think I am going to try out some hawk LTS pads here soon. Not only does powerslot recommend these pads with their rotors, but I have heard they are really good as well.
Old Oct 19, 2007 | 06:36 AM
HankL's Avatar
HankL
I also have a set of Hawk LTS pads that have yet to go in,
simply because I am waiting for the Bendix pads to wear out.
The Bendix pads are just a bit over 60,000 miles
and look like they will last at least 10,000 to 15,000 more.
It would be a great benefit to other 2nd gen Ram owners
if people would consider doing some 60 to 0 test stops
before and after brake pad changes.
I usually find a flat piece of highway that has an expansion joint
that I use as the 'start' for the test stop when I feel the tires hit the joint.
With the Bendix pads a 60-0 stop takes about 175 feet for me
with a 5400 lb Ram
Old Oct 19, 2007 | 10:33 AM
DevilsReject
Noob Assassin
I'd recommend Hawk pads to anyone....they are the best I've ever used....
