TIMING fluctates up and down
Old Oct 21, 2007 | 02:16 PM
Aircates's Avatar
Aircates
Default RE: TIMING fluctates up and down
I just went out and checked mine with a Genisys scan tool. It was pretty much the same thing. I would suspect that this might have something to do with pcm trying to keep the catalytic converter "lit off" I used the grafting feature on both O2 and ignition advance. Although they were not exactly the same, I could see a pattern to them both. I would call it normal...
Old Oct 23, 2007 | 09:25 PM
bill022572's Avatar
bill022572
I really appreciate all the replies. I still wonder about it being normal or just a common problem that no one really notices until it surfaces as something else. I checked a 1999 Durango at work today and the timing at idle only fluctuated between 6 and 10 degrees. Sorry for dragging this up again butI haven't been on here for a day or two.
Old Oct 23, 2007 | 10:00 PM
steve05ram360's Avatar
steve05ram360
you know... after reading this thread again, I recalled that the base timing is not adjustable and the timing will fluctuate at idle. my suggestion now would be to find another ram or magnum equiped truck/van/suv and see what theirs reads... I bet it's the same.
Old Oct 23, 2007 | 10:25 PM
bill022572's Avatar
bill022572
I checked a 1999 Durango and it fluctuated between 6 and 10 degrees which is quite a bit less than mine. As soon as can find a truck exactly like mine to check I will. Thanks again.
Old Oct 23, 2007 | 10:27 PM
steve05ram360
shouldnt matter... same motor, similar software controlling it.
check your distributor for play, could be abnormally wearing out.
Old Oct 23, 2007 | 10:35 PM
aim4squirrels's Avatar
aim4squirrels
ORIGINAL: bill022572
That might bea dicey proposition to another Ram owner, "Hey can I stick this probe in your truck?"
Old Oct 23, 2007 | 10:41 PM
steve05ram360
ORIGINAL: aim4squirrels
[sm=icon_rofl.gif][sm=icon_rofl.gif][sm=icon_rofl.gif][sm=icon_rofl.gif][sm=icon_rofl.gif]
Old Oct 23, 2007 | 11:15 PM
bill022572's Avatar
bill022572
I think if your gentle when you ask - it might be all right. But you might have to buy a dinner and flowers to go with it. Anyway - it's interesting to hear you say that about the distributor. That actually makes sense to me. I could see that causing this. Have you ever personally heard of that happening ?
Old Oct 23, 2007 | 11:18 PM
bill022572's Avatar
bill022572
in the interests of correct spelling : I meant "ifyou'regentle".
Old Oct 24, 2007 | 12:10 AM
spaz_22's Avatar
spaz_22
i'd let you check mine if you were closer to see if it was normal..but i have mine with a hypertech, so it may be different...i'm not sure
