Intake Manifold
Old Oct 19, 2007 | 01:04 PM
mikerados21's Avatar
mikerados21
Default Intake Manifold
Okay i know this is my 1,000,000,000 time to talk about intake manifolds but i have 2 questions. What intakes bolt directly up to a 5.2 98 dodge ram 1500 with a 50mm fastman. Also if it says it allows the use of a carburator can i just still use a throttle body on it? (Ex. The Edlebrock Air Gap)
Also how much taller does a dodge ride in the back than in the front?
Old Oct 19, 2007 | 05:22 PM
mikerados21
Default RE: Intake Manifold
anyone
Old Oct 19, 2007 | 09:12 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Im not to sure on which one spacificly but the ones with carb set up, You will not be able to run fuel injection on it. Moparperformace.com has several FI intakes. If you wanted stock any mangum 5.2 or 5.9 will work. If you get a pre 97 it will have the egr set up on it. You can make a cover plater for it no problemsinceyou dont need it.
Old Oct 20, 2007 | 11:27 AM
aim4squirrels's Avatar
aim4squirrels
ORIGINAL: mikerados21
I think a 2" leveling kit is what you'd want.
the Mopar M1 is a performance intake for the magnumengine that is supposed to net some performance gains. You can get one at summitracing.com I believe.
