2-WD front wheel bearing nut
Old Oct 23, 2007 | 02:38 AM
rabbler's Avatar
rabbler
Default RE: 2-WD front wheel bearing nut
180ft/lbs sounds right. The 2000and up 2wd trucks use a 4wd style hub it needs heavy pressure. The nut is a locking type and is not reusable. While this style is technically non serviceable it can be pressed apart and re-greased. Be careful though I don't think you can get the bearing seals if they get damaged during disassembly.
Old Feb 13, 2008 | 05:50 PM
SilverRam_01's Avatar
SilverRam_01
So, on my 2001, I can't grease the front bearings? The drivers side is starting to squeak... and I don't have alot of money.
