low beams?
ok now that i got some time on my hands i can figure out why my low beams arent working..but my high beams work perfectly...now i already checked the fuse...and its just one bulb for low/high ( incase your wonderin) so any ideas..thanks
One bulb with 2 filaments inside.
Check for powerand ground at the bulb socket. (test light)
I believe the center terminal is the ground. You should have power on 1 terminal on low and power on the other on high.
ORIGINAL: harlow00
I just went through the same problem on my 2002 2500. It ended up beingthe multi-function switch on the steering column.
