TPS Mod?
Old Oct 23, 2007 | 08:10 PM
Lambethcp's Avatar
Lambethcp
Default TPS Mod?
Hey guys,
I was attempting to perform the TPS mod but checked the voltage first. It read 0.86V. Will this over voltage also create a sluggish reaction from the throttle? My truck is a 97 Ram 1500 Ext. Cab with the 5.2 engine. I have installed a K&N CAI and the 180degree thermo. No other mods. Any suggestions would be greatly appreciated, my truck is a dog.
Old Oct 23, 2007 | 08:15 PM
dsertdog56's Avatar
dsertdog56
Default RE: TPS Mod?
Voltage should be around .7-.72. It'll help throttle response, but won't make up for improper gearing to tire size, or other possible issues.
Old Oct 23, 2007 | 08:41 PM
Lambethcp's Avatar
Lambethcp
Thanks,
So you are saying that this 0.86V is bad? And I think my tire size is pretty much stock-275's.
Old Oct 23, 2007 | 09:56 PM
steve05ram360's Avatar
steve05ram360
.7~.75 is ideal, your measurement is not bad, just at one end of the spec.
Old Oct 24, 2007 | 11:36 AM
Lambethcp's Avatar
Lambethcp
Thanks,
I am going to attempt to do the mod this weekend and see how it affects the truck.
Old Oct 25, 2007 | 08:12 PM
rango726's Avatar
rango726
i did the mod last weekend and has made my truck soo responsive its great to barely tap the throttle and have the truck respond instantly
Old Oct 26, 2007 | 07:35 AM
trucklover's Avatar
trucklover
I did this mod too, and it does make a difference. I set mine at exactly .75v and it set my check engine light off. So I reset the computer and changed it to .70v and so far it is doing great! The throttle response is a lot better!!
I wonder if I reset it at .75V again and reset the computer if it would accept the new voltage without setting a code? And would that make anymore performance increase?
