stupid noob question
Old Oct 24, 2007 | 03:26 PM
donnypd's Avatar
donnypd
Default stupid noob question
sorry guys, this is dumb, but i cannot get the search engine to give me any results. could someone please point me, or give your oponion, on basic mods to a stock 97 1500. im interested in light offroading, enough power to go up a hill in overdrive, and keeping it from blowing up. also any trials within 50 miles of roanoke va. thanks much.
97 ext cab 5.2 wheel drive. 100k+. green and rust
Old Oct 24, 2007 | 04:07 PM
HellaciousHemi's Avatar
HellaciousHemi
Default RE: stupid noob question
Cold air intake system from K&N or AIRADE. Aftermarket exhuast, performance throttle body,performance injectors,fuel pump, spark plugs, ignition upgrade basically.Those are all I can think of n not using any new internal engine parts.
Old Oct 24, 2007 | 04:11 PM
Cereal Killer's Avatar
Cereal Killer
No need to apologize for not searching. This isn't pavementsucks.com...
Offroading will require mud tires, you might get away with all terrains since you said "light offroading" but I wouldn't have them.
If you wanna keep the thing in overdrive going up hills, especially if you're going to be towing or running oversized tires you should look into getting some lower gears.
Cheap things you can do for a few hp...
Muffler
gut the catalytic converter
Change the air intake setup
50mm throttle body
PCM flash
Things you can do for offroad
Suspension lift
Body lift
Bigger tires
lower gears
bigger axels
Skid plates
Old Oct 24, 2007 | 07:26 PM
WayneC's Avatar
WayneC
All good suggestions above. I guess I'm still stuck on the 5.2 wheel drive![sm=jawdrop.gif] I'm jealous!
Oh yeah, I'm in one of those moods![sm=icon_rofl.gif]
And...[sm=welcomesign.gif]
