Engine Check and very rough engine
ORIGINAL: arcsum68
Read some good things about Sea Foam, any experience with that?
Seems more comprehensive.
Seems like a lot for one product. Is it the best for all applications or is it sorta good for some things but better for others? Like I said I never used it.
It probably won't hurt anything but I don't know if it will work as well as CCC.
Run some fuel injection cleaner through the next few tanks of gas. Chevron Techron is the best; however, nothing short of tearing apart the heads is going to remove carbon build-up. That stuff gets to be rock hard over time and enough build-up.
Will do, thanks for the feedback.
I have run some fuel injector cleaner in there a couple times, not Techron, but I generally get gas at Chevron anyway.
I will report back after the combustion chamber cleaning.
I asked in another thread and was told that the compression should be around 170.
According to what I have read, compression readings will sometimes be lower if tested on a cold engine, so they could be even higher than what I have listed.
After the cleaning I will at least attempt to do it on a warm engine.
The only thing I could find was Seafoam and again, it was highly recommended by the parts store.
Put it in last night and let it smoke up a storm as expected.
Pulled the plug this morning and it still looks great, maybe a little oily from the Seafoam but great other than that.
Drove the snot out of it today and it feels much better than before and I could not detect any pinging even with WOT off the line, and was easily able to get it to ping previously.
I have myboy by myself this weekend so I cant do a compression check, but I am going to run another cycle of the Seafoam through it next Thursday or Friday and do a compression check on Sat after I clean it out again.
I told the parts store guy what my readings were, of course he said that sounds great, you just dont want them too low! I mentioned that even if they werent high, theres too much variation. He didnt think that mattered at all. Almost everything I read says there should not be more than a 10 or 20 percent variation between all cylinders.
Anyway, I will post back next weekend after I run another cycle of the Seafoam through it, I am really hoping the readings are more normal this time to save myself the money of having to do the heads.
Stay tuned
Stay tuned
I too have been having the same type problems... good luck and keep us posted! I STILL have not figured mine out yet... mine is NOT throwing ANY codes as there is NO light on anyhwere :-( Good Luck!
OK, so I ran some stuff through the engine 2x now, once a week ago and once again the night before last and burning it off yesterday.
Did another compression test, and the results arent exactly what I expected.
Had a remote starter this time so I was able to get more acurate descriptions of whats happening
First test went like this
1 197
2 170
3 197
4 172
5 188
6 200
7 181
8 165
2nd test results (these are the values leading up to the final compression)
1 200 (150-180)
2 192 (120-160)
3 197 (130-160)
4 185 (120-150)
5 196 (155-180)
6 193 (130-150)
7 186 (150-170)
8 165 (70-130)
As you can see, the number 2 and number 4 cylinders seem to have caught up with the rest of them, but the number 8 cylinder seems to be holding steady at 165.
The plugs look fine, with the #8 again being a little bit oily.
What now?
[IMG]local://upfiles/67976/3EBFE888B1AB4DDEA25C2B7C1249D312.jpg[/IMG]
1 197
2 170
3 197
4 172
5 188
6 200
7 181
8 165
1 200 (150-180)
2 192 (120-160)
3 197 (130-160)
4 185 (120-150)
5 196 (155-180)
6 193 (130-150)
7 186 (150-170)
8 165 (70-130)
What now?
