Fuel Pump Bad Ground Wire
Old Oct 26, 2007 | 03:58 PM
Stratostreak's Avatar
Stratostreak
Default Fuel Pump Bad Ground Wire
1st off, I'd like to thank everyone for the input on my 94 Ram 5.2L Fuel pump problem.
2ndly, I'd like to close by leaving a post that stresses how important it is to beverydefinatewhen checking the wiring harness for power and/or a Bad Ground BEFORE throwing countless hundreds away on "could be" solutions. I did some checking to see if my pump was getting 12 volts for the prime cycle and when cranking the engine, but I did NOT INSPECT AND OHM OUT EVERY WIRE. If I would have done this, I would have found the problem, instead the shop did...and that was after I've spent my tire allowance...tryingmany replacement parts. At least my Dodge is back again and I've learned a very valuable lesson from all of this. An ounce of diagnostics is worth a new set of tires.
Thanks again. This forum Rocks.
