2001 Ram 1500/360/4WD/auto- won't shift to high gear
Old Oct 26, 2007 | 04:05 PM
ShiftlessDodgeRam's Avatar
ShiftlessDodgeRam
Default 2001 Ram 1500/360/4WD/auto- won't shift to high gear
Hello out there...
I have an '01 Dodge Ram 1500 with 360 v8 auto. It won't shift into high gear when warmed up. Shifts fine while cold,but after a few minutes won't shift into high UNLESS I let off on the gas. Recently changed trans. fluid & gaskets,etc. Can anyone out there help me? Thanks...
"Shiftless"
Old Oct 26, 2007 | 08:23 PM
rabbler's Avatar
rabbler
Default RE: 2001 Ram 1500/360/4WD/auto- won't shift to high gear
How many miles on your truck?
Usually if it won't shift when hot it is bad clutch seals.
Check your throttle/kick down cable and your TPS for possible problems.
