Top End
Old Nov 2, 2007 | 12:35 AM
mikerados21's Avatar
mikerados21
Default Top End
Okay I know my motor has issues and stuff but i raced a 03 chevy z71 and it always sucks me up and passes me towards the end of the race. Im looking for top end on my motor. any suggestions??>
Old Nov 2, 2007 | 12:58 AM
dwnlowx's Avatar
dwnlowx
Default RE: Top End
SOUNDS LIKE YOU NEED THE HYPERTECH POWER PROGRAMMER
Old Nov 2, 2007 | 09:17 AM
TurboABA's Avatar
TurboABA
Default RE: Top End
What do you mean by "issues and stuff"? If you are already not running at top notch, there's no point in trying to soup it up even more!
Old Nov 2, 2007 | 02:49 PM
TurboABA's Avatar
TurboABA
Default RE: Top End
ORIGINAL: dwnlowx
You really think an extra 3 peak HP will make that big of a difference? There's a spot in the midrange where he will hain 7hp, but it still won't do miracles!!
Old Nov 2, 2007 | 06:58 PM
mikerados21
Default RE: Top End
ORIGINAL: TurboABA
Well i have very bad compression. Im getting a 318 thats used with only 60k on it. My first things i want to do before motor goes in and truck is put back together is.
1.7 Harland Sharp Roller Rockers
Dual Electric Fans
M1 intake manifold
Underdrive Pulleys
SCT Flasher
You think that will rack me in the high 14's?
Old Nov 2, 2007 | 08:05 PM
XXL 1500's Avatar
XXL 1500
Default RE: Top End
that would do ok... but a 360 would do a hella lot better.
Old Nov 3, 2007 | 10:43 AM
TurboABA's Avatar
TurboABA
Default RE: Top End
What do you find your problem is at the track? Post up some slips.
What are your 60' times like? What are your trap speeds? Little bolt on stuff won't do much.
I would change the gearing as my first and most effective mod. Are you still runing an open diff? If so, that's garbage, so throw an lsd or locker in there so that you can put the power to the ground.
If you show us some slips, we can get a better idea of where you are now, and what can be easily improved. Also, have you checked why your compression is low? It could be as little as a gasket?
