SQUEAKIN!
Old Nov 2, 2007 | 03:31 AM
Cowgirl4christ's Avatar
Cowgirl4christ
Default SQUEAKIN!
Ok I have a major squeakin problem... Every time I turn the wheel its like all of the steering is just winding and it squeaks this horrible embarrassing squeak. Also, every time I hit a bump it squeaks. I go muddin a lot and this past time after I went, I had a bad death wobble from all of the mud caked up in the undercarriage. I took it to the truck wash and cleaned the hell out of the truck. Well apparantly I washed out all of the grease for the upper/lower arms, etc. So now I have this squeakin problem. My tie rod ends are the factory greased ones so I can't regrease them. But I don't know if that's whats squeakin. I know for a fact that the upper arm needs greased but what all should or can I get regreased? [:@]
Old Nov 2, 2007 | 05:15 AM
kstroeher's Avatar
kstroeher
Default RE: SQUEAKIN!
Cowgirl, see this post for your problem. Might help.
https://dodgeforum.com/m_1023845/mpa...tm.htm#1024456
Old Nov 2, 2007 | 09:32 AM
ONECRAZYJEEP's Avatar
ONECRAZYJEEP
ckeck your ball joints that may solve all your problem.
