Fastman Install
Old Nov 3, 2007 | 03:00 PM
xskylinedx's Avatar
xskylinedx
Default Fastman Install
Just got back from installing my Fastman 52mm TB. Holy S*** what a difference. I had installed a K&N FIPK a week ago and that made a decent increase on the high end, but nothing compared to the TB swap. Crisp throttle response and I can feel more power from the motor. To top it all off my truck wasn't shifting out of first gear at WOT but now it will, not real sure how that happend but i'm not complaining. Actually, if anyone can shed some light on why that fixed my first gear shift at WOT i'd appriciate it. Glad I took everyones advice on the Fastman TB.
Old Nov 3, 2007 | 03:04 PM
superdak05's Avatar
superdak05
Default RE: Fastman Install
dan has a fantatic product. maybe all you needed to do was play with the linkage from the throttle body and that was just enough to make the tranny shift. dodges are funny like that.
Old Nov 3, 2007 | 03:33 PM
Ramdamit98's Avatar
Ramdamit98
http://www.v8performance.com/tipsandtricks.htm#TVCable
TV cable adjustment. The cable was probably out of adjustment and once you re-installed your throttle body it shifted and now is allowing for shifting at WOT. At least that's my guess on the change in shifting from before to now.
Old Nov 3, 2007 | 03:45 PM
xskylinedx's Avatar
xskylinedx
I had already been messing with the TV cable adjustment prior to the fastman install. (thanks for the link by the way) When I did the install I left the TV cable alone execpt to unhook it from the old TB, so no adjustments were made today.
