throttle body
Old Nov 8, 2007 | 12:53 PM
98Woo2500's Avatar
98Woo2500
Default throttle body
Which one is better Fastman or Holley?
Old Nov 8, 2007 | 01:27 PM
motorbrreath's Avatar
motorbrreath
Default RE: throttle body
fastman is a holley modified. so go with the fastman
Old Nov 8, 2007 | 02:19 PM
98Woo2500's Avatar
98Woo2500
so, if i am going to do more towing, should i get the 50mm
Old Nov 8, 2007 | 02:29 PM
ron333's Avatar
ron333
Look at www.thefastman.com website. He recommends the 50mm for the 5.2L and also for the 5.9L if you do much towing. I just installed mine this week and it has definitely improved throttle response and low end torque. He does excellent work! He can help you with any questions you might have as well.
Old Nov 8, 2007 | 04:51 PM
greenmachine's Avatar
greenmachine
I believe you are referring to the aftermarket Holley. It is a 52mm which will be more than what you need if you have an unmodified motor and want to tow. Unless you just want to pay for a big chunk of aluminum I would go with The Fastman 50mm. A bit cheaper too.
