Water girgling noise???
Old Nov 9, 2007 | 05:03 PM
xtremewlr's Avatar
xtremewlr
Default RE: Water girgling noise???
ORIGINAL: EricCartman
Interesting comment... I guess that can be the caseon some cars/trucks. Probably is the case for Dodge.Butmy old school Toyota 4runner has a control valve on the hose that enters the heater core that is controlled by the heat control slider.
I do it out of habbit - and it's not like it is going to hurt anything.
Cartman.
This is correct. There are SOME cars/trucks that have a valve like that inline of the collant to the heater. Toyota trucks like your 4Runner and the little Toyota pickup I used to have are prime examples. The 1989 Jeep Cherokee I used to own also had something similar but was a vacuum operated valve. Many other vehicles run coolant thru the heater core at all times tho like VWandDodge is saying. Dodge Rams are an example of that.
radio flyer's Avatar
radio flyer
so how does air get into the system to begin with? poor service ? internal engine fault?
Old Nov 9, 2007 | 06:24 PM
Ramafication's Avatar
Ramafication
leaks, improperly filling the rad and bleeding the system, etc...
Old Nov 9, 2007 | 06:28 PM
EricCartman's Avatar
EricCartman
Usually it will happen when you drain the system... as the water goes out, air goes in. It's pretty hard to get the sytem 100% empty. There is usually some coolant that is left inside. Depending on where it is at... it can trap pockets of air in the cooling system..
Cartman
Old Nov 9, 2007 | 10:58 PM
ccdmader's Avatar
ccdmader
I had the same problem, it was caused by flushing the rad and just refilling it. After much searching and a little help from this board I finally got it fixed (the heat workd better now).
I actually took a floor jack and jacked up the passenger side of the truck as far as I could get it, I have been battling this for some time so I got it as high as I could, rear tire was almost coming off the ground
This worked for me, the noise is gone and my heat works.
Chris
Old Nov 10, 2007 | 09:08 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Cartman.
No problem. I guess it is better safe than sorry. [&:]
Old Nov 15, 2007 | 01:48 PM
mrsweet69's Avatar
mrsweet69
I've been having that problem as well. Never knew what it was though, thanks for the post. I was alsowondering if this could have anything to do with a possible heater core problem. My windows won't defog most of the time (at any temperature) and there is a bit of a smell inside the cab sometimes. Do these two things have anything in common? Any insight would be helpful, thanks again!
Old Nov 15, 2007 | 03:30 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: mrsweet69
Yes, your heater core is shot and I bet it looks like this:
Old Jun 10, 2009 | 09:43 AM
capsap33's Avatar
capsap33
Thanks for the solution to the "girgling" noise and slight smell of coolant (only when running heater for about 30 secs then goes away), but absolutely no leaks of any kind! 99 Ram 1500 I've had this sound since owning it, but never any probs - good heat, good ac (probably could be a bit colder, but that is a work in progress - going to be insulationg my cold ac line with heat reflective tape on top of the aluminum foil wrapping i have since reading about guys REALLYU insulating that cold ac line thickly and having REALLY good results - some with as much as a 10 degree drop in temperature for ac!!) and being I'm a cheap-o, i will do this procedure and keep on truckin!
