95 misfire
Old Nov 9, 2007 | 11:51 AM
motorbrreath's Avatar
motorbrreath
Default 95 misfire
Will a 95 throwa misfire code?Im lookin at these wires and one of mine is stripped down to the white core... would this cause a mis? I dont understand where this buckin on the highway is coming from.
Old Nov 9, 2007 | 12:07 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
Default RE: 95 misfire
Should, but the odler stuff is not as sensitive. Misfires are detected when CMP/CKP correlation suggests that a cylinder or cylinders didn't fire. It has to happen so many times in a misfire cycle for the PCM to throw a hard fault.
Obviously you need wires, though, if one is rubbed through to the core. Probably your issue.
Old Nov 9, 2007 | 12:16 PM
motorbrreath
yea thats what i figured, im just so tired of the constant work. im gettin a bump/buck at highway speeds until i step up the throttle and it goes away... it aint the plenum i checked it yesterday. so yay i guess ill drop another 200 on cap/rotor/wires.
Old Nov 9, 2007 | 12:41 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Check your wire routing before spending all that money swapping parts. Throwing money at the issue, rather than properly diagnosing the problem, is no way to reach a resolution.
