Do-It-Yourself Gear Change
Old Nov 17, 2004 | 11:53 AM
Silver_Dodge's Avatar
Silver_Dodge
Default Do-It-Yourself Gear Change
Anybody ever do a differential gear change themselves. My local 4x4 shop wants $1300 to do the front (Dana 44) and the rear (9 1/4). I am wanting to go from the stock 3:55 gears up to either 3:90 or 4:10. How difficult is this to do yourself (I'm mechanically inclined).
Thanks.
Old Nov 17, 2004 | 12:10 PM
Dodgegirl19's Avatar
Dodgegirl19
Lady Administrator
Default RE: Do-It-Yourself Gear Change
Hello... I'm sure you don't want a girl answering this, but I just went through it so here goes...
I'm SURROUNDED by Mopar Mechanics here. I had a new gear, posi unit and chrome differential cover to install. I had to ask and beg for weeks. They kept saying it's tempramental and if something goes wrong, it's a big time problem (duh) and they don't want to risk it. And these are full time dealership mechanics. I even asked my friend George who does a little bit of everything... he works for Rousch Racing here in Michigan. $1300 is very pricey... my local Rack and Pinion shop wanted $350 for what I listed above. I ended up paying $135 to a mechanics I begged and pleaded with. LOL!
Anyway, my point is it's nothing easy stuff... I'd say, last resort, do it yourself. Not because I think you can't, but it's a big, time consuming job. If you need the truck by Monday for work or something... I'd be careful having a novice mechanic tackle it.
~Amanda
Old Nov 17, 2004 | 12:42 PM
Silver_Dodge
Thanks for the info. Anyone else think this is too pricey. Here is the breakdown the 4x4 shop gave me:
Rear gear and pinion - $196.00
Front gear and pinion - $187.00
Front carrier - $47.50
Labor - $385 per axle
plus tax and gear lube
Thanks.
Dodgegirl19
Lady Administrator
I think the labor is a tad pricey, this isn't a dealership, right?
~Amanda
Old Nov 17, 2004 | 12:49 PM
Silver_Dodge
No, it's a 4x4 specialty shop. The dealer price was even more.
Old Nov 17, 2004 | 12:54 PM
GMsucks's Avatar
GMsucks
Labor is hella pricey. 2.5 hr. per axle = $154.00/hour
Why do they say you need a new carrier?
Old Nov 17, 2004 | 12:56 PM
Dodgegirl19
Lady Administrator
Wow... I still think the labor is a tad pricey... I understand they are charing you for two jobs... but more often then not... they are charging by the hours their books says it'll take, so it says, for example, 4 hours to do your front end and 5 to do your rear. You are being charged for 11 hours, but it might only take them 7 hours to actually do the work. I HATE that...
I do think everything but the labor is perfect... and way you can talk to them about maybe doing it for a little bit of a price break since you are bringing a large job to them? Do you know any other mechanics that could do it under the table?
~Amanda
Old Nov 17, 2004 | 01:12 PM
moparturd's Avatar
moparturd
If that's new bearing, gears, shims, lube, and labor, that's not too bad. Have you explored finding the entire housing with the correct ratio from a salvage yard and just installing the whole thing?
Old Nov 17, 2004 | 01:26 PM
Silver_Dodge
ORIGINAL: GMsucks
They said it would be 5 hours per axle.
About the carrier, they say they recommend it basically so everything is new. They told me that 7 times out of 10, the carrier needs replacing anyway once they get in there, so they just put it into their price quote so it doesn't suprise the customer later.
Old Nov 17, 2004 | 01:30 PM
Silver_Dodge
ORIGINAL: mopartodd
I have thought about that, but I would be too worried about the condition of a used diff. If it has problems, I might end up having to have work done on it anyway. This would defineltly cost more in that case.
